Comparaison Yeasu FT991 vs ICOM IC7600
Voici une comparaison intéressante :
Impressions de W9JH :
I purchased the FT-991 to use in my winter QTH where I have a rather small desk. If I had more room I would probably have my 7600 here because of all the other features it comes with.
However, having said that here is what I like about the FT-991 in comparison:
Receive Audio: The receive audio is the best I have heard from all the radios I have owned when using only the internal speaker. The 991 receiver is also quieter and less fatiguing when listening for extended periods. The 7600 requires a quality external speaker to achieve a more pleasing sound.
Selectivity: Last night on 40M there were two strong signals within 2Khz of each other. I was able to listen to the one station that I was working by making simple adjustments to the Notch and Shi ft settings I could likely have accomplished the same with the 7600 but I was pretty impressed with the results on the 991.
Sensitivity: I have no way to compare that to the 7600.
Transmit Audio: I get excellent audio reports with the FT-991 using the standard hand mic and factory settings. The hand mic on the 7600 is fine but I get much better reports using a Heil PR-781. I also tweaked the EQ settings to get the best results. I expect using a PR-781 and/or adjusting the EQ on the 991 would make it even better as well.
I am very happy with the FT-991 and enjoy using it. Quite a nice rig for the size and price.
73,
Jack W9JH
- Réception supérieure :
Rien d'étonnant à cela, le DSP du FT991 est plus récent et le roofing filter du FT991 est au moins équivalent à celui de l' IC7600. - Emission intéressante : Le FT991 bénéficie sans doute du traitement audio des derniers Yeasu qui ne reproduit pas le "grain numérique" que nous pouvons entendre dans les émissions d'un IC7600 notamment.
» ICOM IC7600 et Micro Heil PR781 : Réglages
» Logiciel Mise à jour de l'heure via liaison USB pour ICOM IC705 IC7100 IC7300 IC7600 IC7610 IC9700 IC7850 IC7851
» IC7600 vs IC7410
» FT-890 YEASU : Panne audio en CW et SSB
» Yeasu FTdx101 : Pannes rencontrées
» IC7600 vs IC7410
