Historique des mises à jour du FT2000 / FT2000D
Historique des mises à jour du FT2000 / FT2000D Empty Historique des mises à jour du FT2000 / FT2000D
Message  F5PBG le 25/10/2012, 00:09
Améliorations apportées sur le FT2000 / FT2000D
en fonction des versions logicielles :
FW Ver 0121
1.DVR noise burst
2.DNF update
3.Noise Blanker update
4.60 Meter mode data corruption
5.SSB talk power
6.Speech Processor update
FW Ver 0124
1.This fixes the ADJ. ERR problem.
FW Ver 0127
1.Changes Tot timer default and a Equalizer default
FW Ver 0129
1.Permit full break-in QSK operation up to 40 WPM.
2.Permit CAT command EX1205 acknowledgement to 20 khz.
3.The 139 tUad PE3 LVL default is changed from +6 to+3.
FW Ver 0131
1.Permits monitoring the recording contents in DVS during the transmission of a message that was deleted after v o124
FW Ver 0133
1.MENU116 add 5Hz step to tuning dial steps
2.The
software version can be displayed on the radio Old the three buttons
GEN+50+ENT then turn the RADIO ON the software versione wil be displayed
for 2 seconds as XX.XX Y.YY
 XX.XX as DSP version and Y.YY as FW: 10.24 1.33
EDSP Ver 10.29  (for > V.120 only)
1.Improve the FM audio (check exactly procedure)
FW Ver 0134
1.MENU053/055 correct keyer bug
2.Permit monitoring DVS on the internal/external audio speacker during TX that was affected by v0133 on some radios
3.not explained on the readme: changed the GEN-50-ENT routine with "BLACK LCD" during EDSP/FW release info
FW Ver 0135
1.Upgrade for customer service nd factory allignement only! Without change from 1.34  !?!
FW Ver 0137
- Addition of CAT command "RI" (To turn "TX""RX" on and off in PCC)
- The QMB marker 014 diSP QMB MKR is corrected to center.
- Change MIC-SEL 073 F3E MIC SEL so the Front is not chosen for DATA/PC in-put.
PITCH and SPEED will be displayed for two seconds when the control is
adjusted. It is no longer necessary to hold the Keyer or Monitor button.
- Provide a more noticeable change for MENU SHAPE and PASSBAND.
 SHAPE: 093 rdSP CW SHAP, 096 rdSP PKT SHP, 099 rdSP RTY SHP, 102 rdSP SSB SHP
 PASSBAND: 094 rdSP CW SLP, 097 rdSP PKT SLP, 100 rdSP RTY SLP, 103 rdSP SSB SLP
- Output value of the MENU SHAPE DSP is reversed.
- The Carrier Point frequency is optimized for CW reception.
- Correct WIDTH indication to show correctly during Antenna Tune operation.
- Correct the Tuning Offset Indicator during Power On at PITCH 300Hz CW mode.
FW Ver 0138
Corrected a “bug” of version 0137. In split frequency operation, which
caused incorrect mode change between the sub VFO-B and the main VFO-A on
RX
- Reduce the response time of the main & sub S meter, for more suitable readings.
FW Ver 0139
-Implement 50 ms hold time for SSB TX Power meter.
-Eliminate crackling noise from CW full break in monitor.
-Roofing filter Auto selection no longer reverts to 15 kHz when NB is enabled.
-Permit AF (MONI) monitor in the Packet mode (PKT).
-DMU monitor MENU name changes:
 No.116 MAIN DIAL STEP ? DIAL STEP
 No.117 MAIN DIAL CW FINE ? DIAL CW FINE
- Add a curve to NB GAIN control (a curve same as RF-GAIN).
- Also includes all previous updates.
FW Ver 0140
- Corrects a bug (CAT on RX MAIN VFO-A) found in Ver.0139.
FW Ver 0142
- Add MENU #031 CAT IND. CAT data activity Indicator ENABLE/DISABLE (C/S button LED)
-Add MENU #015 LVL IND. Values are now indicated on the VFD display for
PITCH / SPEED / CONTOUR NOTCH / DNR/ CW DELAY / VOX DELAY
(Press the [ENT] key to set the command to “ON” or “OFF”)
- The AGC HOLD TIME default values are changed.
- Corrected a bug during TX; now the MIC-EQ is updated by PCC-2000 commands.
- Changed MENU PRMTRC EQ LEVEL range of values to -20 ~ 0 ~ +10.
- Changed the default values of MENU PRMTRC (LVL)
- Added the CAT Command (CO) for APF, ON
- Improve the ACS operation.
- Changed the VOX DELAY time settings to approximate the “CW Semi-break-in” DELAY setting on the front panel knob.
After installation of Ver. 0142, you may find that computer operation
with PCC-2000 may not be possible for setting proper MENU items. We will
release the updated PCC-2000 software when it becomes available.
The updated Menu Mode List is available on our web site. Click on the
Files tab in the FT-2000 section and the FT-2000/D “PEP2000” Menu Mode
List (1/01/09) is located under Software.
* The updated FT-2000/D Operating Manual will be posted on the website around mid January.
EDSP Ver 11.29
- Implements the FTdx9000 (PEP9000) DSP technology
- DNR : superior SSB mode noise reduction
- DNF : greater reduction of beat tones
- AGC : attack time fine-tuned
- SSB speech processor audio augmented
- Activate RTTY monitor while transmitting
- DELAY characteristic of AGC close to analog AGC
EDSP Ver 11.39
- It has improved RX-TX switching noise and an important engineering change
- No operational changes are included.
FW 0143 - EDSP Ver 11.45
Ver. 0143 MAIN CPU implements improvements (also includes previous Ver. 0142 updates):
Added values are now indicated on the VFD display for MIC, PROC and RF
PWR. (Press the [ENT] key to set the command to “Enable” or “Disable”
MENU #015 LVL IND).
- Changed the position and the set point of the
PROC knob. The 10 o’clock setting provides 5 to 10 dB compression. (*It
is recommended that you utilize the monitor function and adjust the
[PROC] knob suitable audio, between 9:00 to 12:00 o’clock position).
Ver. 11.45 EDSP implements improvements (also includes previous Ver. 11.39 updates):
- The characteristic of the CONT LEVEL is changed.
- The characteristic of the MIC and PROC LEVEL is changed.
- Detection frequency precision of CW-DET.
* If you already have software Ver. 0143 and 11.45 it is not necessary to update the FT-2000/D again.
* The updated FT-2000/D Operating Manual will be posted on the website around mid February.
After installation of Ver. 0142 or 143, you may find that computer
operation with PCC-2000 may not be possible for setting proper MENU
items. We will release the updated PCC-2000 software when it becomes
available.
FW 0144 - EDSP Ver 11.50
Ver. 0144 MAIN CPU implements improvements (also includes all previous updates):
- Corrects the CAT-CO01 command problem found in Ver. 0143.
Ver. 11.50 EDSP implements improvements (also includes all previous updates):
- Corrects a low audio problem found in Ver. 11.45.
- Corrects the CW-DET indication problem found in Ver. 11.45.
* The updated FT-2000/D Operating Manual will be posted on the website around end of February.
After installation of Ver. 0142, 0143 or 0144, you may find that
computer operation with PCC-2000 may not be possible for setting proper
MENU items. We will release the updated PCC-2000 software when it
becomes available.
FW 0145 - EDSP Ver 11.50
Ver. 0145 MAIN CPU implements improvements (also includes all previous updates):
- Level Indications are added for the SHIFT and WIDTH.
- The CW-DET indication is improved
- Corrects the CAT BP command
- Falsing of LEVEL INDICATORS is improved
Frequency or Level display is shown instantly when the VFO knob or
level adjustment knob is rotated (Level items turned on listed in MENU
015) Ver. 11.50 EDSP implements improvements (also includes all previous
updates):
After installation of Ver. 0142 ~ 0145 you may find that computer
available.
FW 0146 - EDSP Ver 11.50
Ver. 0146 MAIN CPU implements improvements (also includes all previous updates):
- Correct the PC keying.
- Corrected the TX power level indication.
NOTE:
The
level indication requires a quicker knob rotation to activate, before
making fine adjustments. A slow knob rotation may not activate the
display.
After installation of Ver. 0142 ~ 0146 you may find that computer
available.
FW 0147 - EDSP Ver 11.53
Ver. 0147 MAIN CPU implements improvements (also includes all previous updates):
- Improve response time of the values indicated on the VFD display.
- Correct the PC-keying.
- Correct the INDICATOR VOX-DELAY.
- Correct the AM reception GAIN.
- Correct the MEMORY KEYER output.
- Eliminate the "MIC EQ "indication in CW mode.
- Change the VFD indication of MENU #34 TRACKING from "FrE9" to "FrEq".
Ver. 11.53 EDSP implements improvements (also includes all previous updates):
- The DNR algorithm is not reset between TX/RX, to eliminate the increased receive noise after a transmission.
- Increase the response of the compression level meter in conjunction with the PROC knob. (Max up to 12dB).
NOTES:
* Rotate the [METER] switch to select “COM” (Compression). We recommend setting the PROC level within the 5dB to 10 dB range.
When menu settings are saved on the DMU-2000 CF card and transferred to
the new version, some previous versions may not transfer correctly.
Please check your menu, update the settings, and then save the new
settings to the CF card.
* After installation of Ver. 0142 ~ 0147 you
may find that computer operation with PCC-2000 may not be possible for
setting proper MENU items. We will release the updated PCC-2000 software
FW 0148 - EDSP Ver 11.53
Ver. 0148 MAIN CPU implements improvements (also includes all previous updates):
- Corrects the INDICATOR (NOTCH, CONT and uTUNE).
FW 0149 - EDSP Ver 11.53
Ver. 0149 MAIN CPU implements improvements (also includes all previous updates):
The REC (Record Function) setting will be recalled when the power is
turned on if REC was turned on before power was turned off.
- The CAT MW command is corrected.
- In the QMB-MT mode, when the VFO frequency is moved, the memory channel indication is cleared to 0.000.
- The DSP firmware write mode may be accessed by pressing [CONT] + [DNR] while pressing Power On.
- Holding of the [?]F6 or [?]F7 keys will permit scrolling through the DMU Memory Channel List, when the DMU-2000 is installed.
- The FH-2 [UP][DW]keys are made the same function as the MIC-UP/DN keys.
- Corrected the CW FULL BKIN keying when used with the VL-1000 Quadra Amplifier System.
- Corrected the RX in CW FULL BKIN 30wpm.
NOTES:
* Rotate the [METER] switch to select “COM” (Compression). We recommend setting the PROC level within the 5dB to 10dB range.
FW 0150 - EDSP Ver 11.53
Ver. 0150 MAIN CPU implements improvements (also includes all previous updates):
-  The FH-2 [<-][->] keys are made to increment the frequency at 100kHz up or down.
- CW carrier is corrected to change LSB <> USB when the indication is changed on VFO B.
- Correct the CW Auto Mode.
- DMU Band scope Display Signal Peak Frequency is centered.
FW 0150 - EDSP Ver 11.54
- CW carrier is corrected to change LSB ? USB when the indication is changed on VFO B.
Ver. 11.54 EDSP implements improvements (also includes all previous updates):
- Corrected FM TX for a slight frequency offset.
NOTES:
FW 0151 - EDSP Ver 11.54
Ver. 0151 MAIN CPU implements improvements (also includes all previous updates):
- AGC: Corrected the AGC in the “OFF” position; if an AGC MENU SET item was changed, the AGC would sometimes turn “ON”.
- KEYER: The extraneous “dot” memory is eliminated during rapid keying when the dash output starts.
- CAT: Corrected the 1.5 kHz shift when the CAT “FA” command is used to change the frequency on the 5MHz band.
- SCOPE: The right edge signal position on the display is corrected.
- SCOPE: The left edge signal is corrected when the frequency is changed on the display.
NOTES:
FW 0152 - EDSP Ver 11.54
- Stabilize initial power on display.
FW 0155 - EDSP Ver 11.54
Ver. 0155 MAIN CPU implements improvements (also includes all previous updates):
- Long press the [RX-B] button, to access TRACKING MENU; long press the [RX-B], again to toggle back to normal.
- The beacon setting MENU time is changed. The new setting is up to 690 seconds.
- Corrected the DMU (SCP) FIX mode, upper band limit out of range.
NOTES:
FW 156 - EDSP Ver 11.54
Ver. 0156 MAIN CPU implements improvements (also includes all previous updates):
- The USA 5MHz (60m) channel frequency change US3 (5.368MHz to 5.3585MHz).
- Permit CW transmission on the USA 5MHz (60m) channels US6 - US0.
- Changed the MIC-GAIN level indication of AM/FM to the MENU setting value.
- Disabled the PROC function in AM/FM.
NOTES: After installing main software Ver. 0156;
- For US1 - US5 channels the USB mode is fixed. For channels US6 - US0 the CW-USB mode is fixed.
- PKT-PTT transmissions will disconnect the microphone.
- The TNC (PSK sub carrier) setting must be 1.5 KHz.
·  Corrected FM TX for a slight frequency offset.
FW 157 - EDSP Ver 11.54
Ver. 0157 MAIN CPU implements improvements (10/22/12)
. The KEYER BUG-key [REV] setting, when the DASH side was pressed, produced two dots, is corrected.
. The intermittent VOX operation at AF-GAIN minimum setting of VFO-B CW mode is corrected.
Ver. 11.54 EDSP implements improvements (4/23/10)
・  Corrected FM TX for a slight frequency offset.
FW 158 - EDSP Ver 11.54
Ver. 0158 MAIN CPU (02/13/13)
. Correct minor bug and implement improvements
Ver. 11.54 EDSP (12/07/09)
FW 159 - EDSP Ver 11.54
Ver. 01.59 MAIN CPU (03/27/14)
. Corrected the contest number automatic increment when there are two or more "#" (automatic
increment contest number assign) within a transmission sentence, the increment function
automatically is incremented one contest number for one transmission.
*When menu settings are saved on the DMU-2000 CF card and transferred to the new version, some previous versions
may not transfer correctly. Please check your menu, update the settings, and then save the new settings to the CF card.
Historique des mises à jour du FT2000 / FT2000D Empty Re: Historique des mises à jour du FT2000 / FT2000D
Message  F5PBG le 1/3/2013, 08:43
Commentaire sur la dernière mise à jour :
Aucune amélioration du DSP... Si votre émetteur récepteur
est à la mise à jour FW 0152 - EDSP Ver 11.54 de 2010,
inutile d'appliquer la nouvelle mise à jour.
De surcroît, aucune information sur les modifications mineures concernant
Je n'ai constaté aucun bug avec le 0152...
Message  F5PBG le 3/3/2013, 13:42
F5BQP a réalisé la mise à jour de la V1.52 vers la 1.58
sans constater de problème particulier.
Nous ne connaissons toujours pas ce qui a été corrigé
dans la dernière mise à jour... Il est simplement indiqué
"correction de bugs mineurs"...
Message  F5PBG le 7/5/2013, 00:16
Je viens de réaliser personnellement la dernière mise à jour
vu que certains OM américains avaient l'air de signaler une différence
au niveau du DNR.
Je doutais de leur affirmation vu que le logiciel eDSP n'a pas fait l'objet
de mise à jour depuis la mi-année 2010...
J'avais raison de douter. En effet, la dernière mise à jour n'apporte rien
sauf éventuellement le reset des paramètres de votre FT2000, reset
préconisé après la mise à jour (fast+lock+ON).
A noter qu'un RESET n'affecte pas le menu caché du FT2000, seulement
le menu classique.
Dans tous les cas de figure, même si cela un peu de temps, prenez soin
de noter en lieu sur les valeurs du menu classique ainsi que celui du menu
caché.
Message  F5PBG le 1/4/2014, 09:59
Voir listing ci-dessus
Nouvelle version du 27 mars 2014
. Pas d'amélioration de la réception
. Simple correction mineure d'une fonctionnalité utilisée en DX
En résumé, mise à jour loin d'être indispensable...
